mover1's avatar
mover1
Follower
May 08, 2020
Need to find a WiFi extender for my shed 140 feet way from house.
We have Google Fiber in the house and want to extend service out in our newly built shed 140 feet behind the house.
Would it be best to buy Netgear Nighthawk X6S EX 8000 and put it in the garage directly behind the house and then connect an ethernet cable to it and bury that cable with all the new wiring going to the shed and then have a router in the shed?
Would that work or is there a better idea?
1 Reply
  • plemans's avatar
    That'd work.
    And is a pretty decent option as a buried connection is the best option for running that far.
    Any chance you're able to just run the line directly from the router and skip the extender in there?
    Your other option would be using a point to point system like netgear airbridge.
