KBDB
Sep 04, 2024Follower
Need wifi extenders
Hello. Just purchased the AX5400 (RAX54S) and unfortunately the signal is very weak on the upper levels of the house. Are there any wifi extenders that will work with this router? I'd really rather ...
Sep 04, 2024Guru - Experienced User
Any of the EAX lines would work and be AX devices.
You can see them here:
https://www.netgear.com/home/wifi/range-extenders/
The eax line currently has the EAX12, EAX15, EAX20, and the EAX80
If you're only needing one, they're a great option. If you're needing more than 1, then I'd be looking at returning the router and looking at a mesh system.
