ahiqbal
Nov 24, 2019Follower
Net gear AC1200 Wireless Wifi Range Extender (EX6200) Simultaneously extend 2 different wifi signals
Hi, My DSL modem transmts 2.4GHz signals and I have attached a TP link router to the main modem that transmits 5GHz signals. I just wanted to ask does anyone know that can I extend both of these wif...
Nov 24, 2019Guru - Experienced User
You should be able to it fairly easily if you have the SSID's seperated out.
Just make sure to follow the manual setup process on page 17 of the manual. it allows you to select which wifi signal to extend. You'll be able to select which one you want for 2.4ghz and 5ghz.
