Gpspete
Sep 25, 2022Follower
Net gear ACN1200 wifi extender
I have Centurylink 940 Mbps internet. I have 4 Wyse motion cameras. 3 work good on my 2.4 band. 4 camera is back of house with poor signal. I have mounted wifi extender on side of house. Wifi extende...
Sep 26, 2022Guru - Experienced User
What actual extender is it?
What router are you connecting it to?
What method of setup did you use? WPS push button, the installation assistant, the app?
You have the extender mounted outdoors? What are the exterior walls made of? They usually do a good job of blocking wifi which is why the camera's don't connect well
