Profloving
Jul 28, 2023Aspirant
Net gear tech service wanted $110 to renew some security feature in my 3110 Wi-Fi extender
- Jul 30, 2023
So you factory reset the extender, then without hitting WPS, you connected the laptop to the netgear's wireless?
And it showed the netgear_ext address?
And then from there try 192.168.1.250
Jul 29, 2023Guru - Experienced User
Netgear doesn't sell you things like that. Scam sites are great at it though. If you googled for a number that's more than likely what you got.
What actual issue are you having? what is telling you these issues?
Is it more than 1 device or just the single device?
- ProflovingJul 29, 2023AspirantMy wife’s MacBook had one instance of not getting connected. Our echo device and smart tv connect.
I can’t get to Westlaw or the Times, Post, Guardian websites or most everything else. I can get on and use YouTube. One error message has a Netgear title and the link took me to the Netgear site.
I’ve run the Windows malware program, the Bitdefender virus scan and the Lenovo computer health programs and turned up nothing. AT&T can’t figure it out. They said that the lines were unbalanced. They sent a tech. He was perplexed. He swapped out the router, which was 5 years old, for a new one. I still have the same problem. I will try to send a photo of the Netgear screen in a follow up reply. Thanks- plemansJul 29, 2023Guru - Experienced User
do you get the same things on the PC when the extender is powered off?
Try using the extenders IP address to access it and not the mywifiext address.
- ProflovingJul 29, 2023AspirantWhen I type in “NYTimes.com”, I am redirected to “mywifiext (dot) net” The screen shows “NETGEAR”<br>The body reads “You are not connected to your extender’s WiFi network.”<br>It has tabs and when I a click on “HOME”, “BUSINESS” or “SUPPORT”, I wind up on the Netgear site. My EX3110 extender is not plugged in. I “forgot” it on my Wi-Fi connection page. Have you heard of this happening?
Your extender isn't plugged in? You mean to the wall?
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk- ProflovingJul 29, 2023AspirantDuring the process, I reset the extender several times including just now. I unplugged the extender from the outlet and left it unplugged. I went into my Network and Internet settings and forgot the Netgear network. Still not fixed.
I reset just now and tried to reconnect without using the “connect automatically”. It doesn’t connect. When I went back to my AT&T network, I couldn’t get onto the Netgear website to download anything.
