Profloving
Jul 29, 2023Aspirant
Net gear tech service wanted $110 to renew some security feature in my 3110 Wi-Fi extender
- Jul 30, 2023
So you factory reset the extender, then without hitting WPS, you connected the laptop to the netgear's wireless?
And it showed the netgear_ext address?
And then from there try 192.168.1.250
Jul 29, 2023Guru - Experienced User
Netgear doesn't sell you things like that. Scam sites are great at it though. If you googled for a number that's more than likely what you got.
What actual issue are you having? what is telling you these issues?
Is it more than 1 device or just the single device?
Profloving
