Profloving
Jul 28, 2023Aspirant
Net gear tech service wanted $110 to renew some security feature in my 3110 Wi-Fi extender
- Jul 30, 2023
So you factory reset the extender, then without hitting WPS, you connected the laptop to the netgear's wireless?
And it showed the netgear_ext address?
And then from there try 192.168.1.250
Profloving
Jul 29, 2023Aspirant
My wife’s MacBook had one instance of not getting connected. Our echo device and smart tv connect.
I can’t get to Westlaw or the Times, Post, Guardian websites or most everything else. I can get on and use YouTube. One error message has a Netgear title and the link took me to the Netgear site.
I’ve run the Windows malware program, the Bitdefender virus scan and the Lenovo computer health programs and turned up nothing. AT&T can’t figure it out. They said that the lines were unbalanced. They sent a tech. He was perplexed. He swapped out the router, which was 5 years old, for a new one. I still have the same problem. I will try to send a photo of the Netgear screen in a follow up reply. Thanks
Jul 29, 2023Guru - Experienced User
do you get the same things on the PC when the extender is powered off?
Try using the extenders IP address to access it and not the mywifiext address.
