LeaderPikachu
Jul 24, 2021Tutor
Netgear 3700v2 Ethernet Ports Out
I really hope it's not what I think it is. I have tried doing a simple reboot as well as a 2 minute power cycle and my ethernet ports are still out. We had a recent monsoon storm and I wasn't home bu...
LeaderPikachu
Jul 26, 2021Tutor
unfortunately even in the admin login on the browser for the router itself, i can't find where its possible to reinstall the firmware. i purchased a new modem-router, AC1750, exact same problem, contacted my ISP and they claim they not only ran a diagnostic but that supposedly they didn't see a problem. I am contacting Netgear directly as recommended by my ISP but mostly to tell my ISP that I spoke with them.
LeaderPikachu
Jul 26, 2021Tutor
Solution was found! Surprisingly my ISP was right this time (they've been wrong multiple times before and lack faith in them now) but through additional trouble shooting steps and ideas provided by Netgear's IT support. I completely blanked about the netgear ethernet hub i have connected to my network. It apears that may be the culprit, I'll buy a replacement tomorrow and test it out, if that resolves the issue, I will mark this response as the solution for my particular issue!
For additional reference, I was so stressed that I also forgot that my usb-a to ethernet adapter isn't compatible with my macbook, so I assumed the ethernet ports were out. pulled out an old pc laptop with linux installed and that connected to the ethernet no problem, how I came to realize that the ethernet hub may be the cause of my current internet problems.
- plemansJul 27, 2021Guru - Experienced User
Eitherway, glad you got it fixed. if you mark your solution as solved, it might help the next person with that issue
