LisaLisa71
Apr 25, 2023Tutor
Netgear 6100 extender - can't connect to network
PLEASE HELP! I have a ASUS router and a Netgear 6100 extender and had to factory reset the extender. Now I can see it on my laptop WiFi list but when I click it I'm not prompted to add password (as ...
Apr 27, 2023Guru
It won't prompt just by connecting to it.
Once you connect, you have to go to mywifiext . net
then it should take you to a prompt to set it up.
LisaLisa71
May 01, 2023Tutor
Yes, I understand that. When I log on to mywifiext . net it just says "can't connect to network". This is my issue.
