hershy's avatar
hershy
Netgear A7000 preferred band
I have a netgear a7000 usb wifi adapter, I am trying to select a preferred band of 2.4 ghz. However, the preferred band selestion is missing from the wifi configuration.
  • plemans's avatar
    You don't set a prefered band for 2.4ghz.
    Reason why is the router selects what channel its going to broadcast on and the wifi adapter just connects to that one.
    Not 100% as I don't have that adapter but you can usually select whether it prefers 2.4ghz or 5ghz though.
