afsteed
Oct 26, 2025Aspirant
NetGear AC1200 Model EX5000
I am having an issue with my new wifi range extender (NetGear AC1200 Model EX5000). I was able to connect to my primary router using WPS with no problem, and both the 2.5GHz and 5GHz SSIDs appeared a...
Michael3456
Oct 27, 2025Aspirant
It sounds like your EX5000 is auto-switching to the stronger 5GHz band and failing to route internet through 2.4GHz. A few steps to fix this:
- Disable “Smart Connect” on your primary AT&T BGW320 router if it’s enabled.
- This prevents devices from automatically switching between 2.4GHz and 5GHz.
- On the EX5000, manually assign separate SSIDs for 2.4GHz and 5GHz instead of using the default single SSID. Connect your PC specifically to the 2.4GHz SSID.
- Forget the network on your PC and reconnect to the 2.4GHz SSID to ensure it doesna’t try auto-switching.
- If issues persist, try power-cycling both the router and extender after making these changes.
This usually stabilizes the 2.4GHz connection and ensures internet access through that band.
