Dom56470
Feb 26, 2024Follower
Netgear AC1200 model EX6150 never boots
Hello. my wifi range extender is blocked during booting. Power led stays amber, even after I have reset the system (switch activated for more than 30 sec). Is there anything else to do, or shall I ...
Feb 27, 2024Guru - Experienced User
When the powerlight is amber, it usually indicates a failed bootup process or firmware corruption.
You can try recovering it with tftp or nmrpflash.
are you on windows? if so, follow this guide
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP
just make sure you enable tftp
https://www.thewindowsclub.com/enable-tftp-windows-10
and here's a video walk through using a tftp client. Use the built in one for windows 10 though. the video is more of an example of how its done.
https://www.youtube.com/watch?v=R9DLrLQrpaw
and if that doesn't work, you can try using nmrpflash
https://github.com/jclehner/nmrpflash
