Nakatomi
Sep 03, 2020Aspirant
Netgear AC1200 Wifi Extender Issues
I have the above wifi extender and I just recently changed it to become an access point as I have a long cat5e ethernet cable coming from my router downstairs to a netgear 5 port ethernet hub, I did ...
Sep 03, 2020Guru - Experienced User
Log into your router and check the IP address for it. It might have had a new ip address assigned.
Nakatomi
I have been in to my routers settings page and it shows under connected devices EX6120 but it's says its wireless and not connected with a green light, I have copied and pasted items that show up as unknown and none of them work I don't know if I should do a hard reset and try it again but right now its working fine it's broadcasting the same SSIDs for 2.4/5ghz and like I said my phone it working on it fine. I could just leave it since it's working but I would like access to it for firmware updates etc and to check on connected devices and what not I don't understand if it switches to Access point mode why I can't use the same address or find it working in my router settings page
