johnkf
Mar 31, 2021Aspirant
Netgear AC1200 WiFi range extender EXS6190
Having problems with my unit getting the following Message "LAN Disconected then - 5-30 Seconds LAN connected this stops any program that was been streamed then have to re start unit has worked ok fo...
nikim72
Apr 04, 2021Aspirant
johnkf wrote:Having problems with my unit getting the following Message "LAN Disconected then - 5-30 Seconds LAN connected this stops any program that was been streamed then have to re start unit has worked ok for last 6 months usps tracking
Help Pls
Thanks
John
Hey john,
If you config system manually , let it to reset.. May your lan assign similar ip to other devices.. Not sure this could be the problem , but can be one of case... Reset and do again..
