Winbag
Sep 05, 2019Follower
Netgear AC1200 WiFi Range Extender
HI I have 2 of these extenders, worked great until I had to change out my modem and get a new password. I followed online instructions (or so I thought) to get these wirelessly connected. However,...
Sep 06, 2019Guru - Experienced User
Anytime you swap out modems/routers its best to reset the extender back to factory and redo the installation from stock.
Did you do this?
If not, hold the reset button for 7-10 seconds (while powered on) until the lights change. Let it go through the reset and bootup and then try redoing the install using the instructions.
