maybs
Sep 11, 2021Follower
NETGEAR AC1200unable to set up
Hi guys, I am far from any computer amateur and cant set up my range extender. I cant even find the "Netgear' network or wifi icon on my computer to locate it for the set up process. Any help would ...
Sep 11, 2021Guru - Experienced User
you have the EX6110?
what firmware is on it?
what router are you connecting it to?
did you try factory resetting (incase was already setup prior)?
Push and hold reset for 7-15 seconds while powered on.
what are the led's on it doing?
