vondoom2
Jul 11, 2022Tutor
Netgear AC1750 (EX6250)
Question. I purchased the the Netgear AC1750 WiFi Mesh Extender thinking that I would be setting up a Mesh System. But when I started configuring, it came up as NETGEAR_EXT which was how my wifi Range...
- Jul 11, 2022
What firmware is on the EX6250? I know the V1 of the EX6250 had the mesh functions added in with firmware upgrades.
Make sure you're on the latest firmware, then factory reset it. connect to the netgear_ext address and run through the setup leaving the "one ssid" function enabled. that's the mesh feature.
Jul 11, 2022Guru - Experienced User
- vondoom2Jul 14, 2022TutorThank you for that. I totally spaced when setting it up before when it asked to keep as one Network name and I chose no. I had to factory reset it like you said and then from there I had to use the Nighthawk app to set it up. Thanks again.
