spaicd
Jul 10, 2020Aspirant
Netgear AC1750 extender very slow wifi speed
Hi,
Before starting I must say that I already spent 3h on this problem and tried averyting I could find on this community. I also spent 2h with 5 support agents, each time being disconnected and it's just a nightmare... And Im computer ingeneer so I really really dont know what to do anymore or how any less technical profil could get this to work.
This is the basic problem context: when connected to 5G wifi directly to my router, I get 300 mbps.
When connecting to the Netgear extender on 5G I get maximum 20mbps.
In order to exclude the range from my tests, I test everyting in the same room so extender is few feets from the router. I tried also connecting the extender on the floor where it should be and the problem remain the same.
What I already tried:
- 2 modes : separate name and one name for the wifi extender.
- different wifi channels. I tried, 40, 120, 140, auto... I cannot go more than 140 with my router with 20mhz bandwith. WIth 80 mhz bandwith I can get to 112
- I tried using software to check the available wifi channels.. ALl those channels were available and I dont have a lot of wifi networks aroudn me
- I tried downgrading the firmwere from the latest one to the .100
I dont really know what to do anymore. My router model is the SFR router since I am living in France.
Can please anyone help me?
I am quite desperate.
- spaicdAspirant
I tried today with firmwares
1.0.0.80
1.0.0.110
but I cannot get any better than 30mbps on 5G wifi.
I also tried with channels 36,48,64,112 and it is sill the same.
Connected with ethernet cable directly to the extender I get the same results...
Connected directly to router's 5g WIFI I get easily 300mbps.
Any idea?
Thank you
- spaicdAspirant
Just to let you know that I solved the problem by ordering another extender from another competitor.
It's far from perfect but at least I get 40-60mbps with that one.
Cheers
