teazur
Apr 13, 2020Aspirant
Netgear AC1750 Router I bought over a year ago
Let me start with I dont know much about computers so I was hoping someone could steer me in the right direction. I have a NETGEAR Dual-Band AC1750 Router that runs the Wifi in my home. I receintly b...
Apr 13, 2020Guru - Experienced User
*should* work.
When it comes to people wiring/setting up their own stuff, I always preface with *should*. :)
I'd recommend at least a dual band extender or even checking out some of the refurb/renewed routers. benefit to the router is then you have a backup router if the primary goes down. just don't run it in router mode or you'll end up with a double nat issue.
teazur
plemans wrote:*should* work.
How do you go about not running it in router mode??
