Gmike370
Sep 28, 2020Follower
Netgear AC1900 not connecting to Surfboard SB6190
I purchased a Surboard SB6190 to use with my Nighthawk AC1900. Before the Surfboard I had the modem/router xfinity supplies and used that along with the AC1900 and it worked perfectly. I tested the s...
Sep 29, 2020Guru - Experienced User
AC1900 is a speed.
And you put EX7000 in the signature line. Is that what you have? if so, you need a router. The ex7000 doesn't have an integrated router and the SB6190 is a modem only device. No router.
