ePapaleo
Sep 17, 2020Aspirant
netgear ac2200 triband nighthawk
Hello Netgear Community! I recently purchared the netgear ac2200 triband nighthawk because I moved and the wifi did not reach my new office location. I have been able to successfully connect and I ha...
- Sep 18, 2020
To change to .206 firmware you can get the firmware here:
https://www.netgear.com/support/product/EX7700.aspx#Firmware%20Version%201.0.0.206
It is a zip file so you have to unzip it.
Then logon to your router (mywifiext.local on Windows) and you will see that Firmware Update is an option and you can use Upload Update File (it warns you that it is older than the current version). This .206 firmware has been working fine for more than a week (and it worked for months before the extender updated itself to .the .210 firmware). Also, switch off automatic updating of firmware.
DavidRC
Sep 17, 2020Apprentice
Is this the EX7700? If so then quite a few people are having problems with the latest firmware (.210). I have had no problems since going back to the .206 firmware.
- ePapaleoSep 18, 2020Aspirant
DavidRC Well I am relieved to know I am not the only one. I'm not sure how to switch the firmware back to .206 can you advise on that process?
- DavidRCSep 18, 2020Apprentice
