kdon23
Sep 22, 2021Aspirant
netgear ac2200 triband nighthawk
I went thru the set-up successfully, trying to see if the setup is working correctly. When the extender is synced with the router (Nighthawk AX4 Wifi 6 Router RAX40) only the 2.4 ghz light is lit, a...
Sep 22, 2021Guru - Experienced User
what extender do you have? AC2200 is a speed.
Usually with the extenders, the 2.4ghz/5ghz light comes on when a device (phone, tablet, pc, etc) is connected to it. It doesn't signify the connection to the router. Again, not 100% because you didn't include extender model.
Also, I think all the AC2200 extenders are mesh extenders. meaning its your device (phone, tablet, etc) that roams between the router and extender as needed. If you set it up in mesh mode.
- kdon23Sep 22, 2021Aspirant
I bought the Netgear Wifi mesh extender EX7500
