toastyv
Jun 13, 2022Tutor
Netgear AC6250 - Netgear_EXT not showing up
Hi everyone, I recently purchased a Netgear AC6250 Wifi Mesh Extender and have a lot of trouble trying to connect this to my home network. The biggest challenge is trying to find Netgear_EXT. Thi...
- Jun 15, 2022By sheer luck, I managed to get this connected! If anyone runs into this issue, try some of the things I did.
- When holding the factory reset button, hold it for at least 30 seconds.
- Keep trying until you see NETGEAR_EXT. Once I found this on my network I quickly selected it and created my login.
- Moving the Wifi Extender makes a big difference; try different spots, do a factory reset and try again.
Hope this helps someone who has a similar issue.
toastyv
Jun 14, 2022Tutor
Even stranger now... I managed to connect my extender using the Netgear Nighthawk; it just suddenly worked! It even managed to do a firmware update!
The challenge is that when I run a speed test, it says device isn't connected. What's going on now???
toastyv
Jun 15, 2022Tutor
