bmege
Oct 18, 2020Aspirant
Netgear AC750 EX3800 2.4GHz channel selection stuck on auto
I try to setup the EX3800 in range extender mode. How do I force the EX3800 to use a different channel? It is forced to be "auto" which apparently means same channel as the router uses. This obvi...
Oct 20, 2020Guru - Experienced User
When in extender mode, an extender HAS to use the same ssid as the router. reason why is its basically the channel the router is broadcasting/receiving (talking) to the extender on. so if the extender was on a different channel, it wouldn't be able to communicate with the router.
Also, the problem with setting an extender with the same ssid as the router (when it isn't a mesh device which the ex3800 isn't), is that they're sticky. There isn't a roaming protocol so device don't roam until they've lost signal or its dropped so much its useless.
