PRBW
Apr 03, 2021Follower
Netgear AC750 Wi Fi Extended Model EX3700
I am trying to install extended AC750. The direction instructs to push WPS on router. My router is 2.4 and the Security is WPA2. There is no button to push. Is there a work around or do is this ext...
Apr 04, 2021Guru - Experienced User
Yes, you can use the installation assistant instead of using the wps method.
the support site has a guide as well as a video on it (2nd video I think)
