michellen97
May 17, 2020Aspirant
NETGEAR AC750 Wifi Range Extender not working
Hello! I've had my NETGEAR AC750 Wifi Range Extender Model EX3700 for about 9 months. It is only used for connecting the LAN cable to PS4 or a laptop. Suddenly today it stopped working even after a factory reset. No signs of life from it. Any suggestions? Thank you!
Any of the led's lit up? If so, which ones/color/solid/blinking?
If none light up, i'd start the rma process. Click mynetgear at the top, register an account and then the device. from there you can start the rma process.
- plemansGuru - Experienced UserBtw, there is an on/off button. I know it sounds stupid but you did turn it on?
- michellen97Aspirant
I tried on/off button and factory reset. Nothing. Thanks for your response
None of the lights are blinking. Will make a ticket for replacement. Thank you for your response!
