frostywhif
Jul 11, 2022Follower
Netgear AX1800 4-Stream WiFi Mesh Extender
I purchased a Netgear AX1800 4-Stream WiFi Mesh Extender and got it installed successfully. It appeared to work correctly until recently when the Router Link LED was occasionally amber. I tried to tr...
- Jul 11, 2022
A couple things.
1. don't use the app.
2. factory reset the extender. Push and hold reset for 7-15 seconds while the extender is powered on
3. you can hardwire into the extender for setup. Do that. Don't use the app or WPS for setup. Use the installation assistant.
what router are you connecting it to?
Jul 11, 2022Guru - Experienced User
A couple things.
