accountvmb's avatar
accountvmb
NETGEAR AX3000 WiFi extender setup no netgear_ext WiFi found to connect to
I have the above extender.  It connected to my former router fine.  New router (same kind as former) and there is no netgear_ext WiFi to connect to.  I tried reset, etc.  same result.  Is there a fix for this?
  • Thank you!  That worked!  Note for others on this topic:  T-Mobile 5g cell routers don’t support WPS setup.  I had to move the extender to within 10 feet of the router before I reset it.
  • plemans's avatar
    Usually people don't end up holding reset long enough or while powered on.
    While its powered on, push and hold reset until the lights blink. Usually 7-15 seconds.
    That should get it back to the defaults.
    You can also try the WPS version of install. That works well with most newer devices.
    • accountvmb's avatar
      accountvmb
