dlange1234
May 28, 2024Aspirant
Netgear C7000v2 and EX6400v3
I am using AC1900 (model C7000v2, Firmware v1.03.08) in my home but the wifi signal was not making back to one of the rooms we use for streaming movies so I purchased the EX6400v3 (firmware V1.0.3.32...
- May 31, 2024
This is how to disable the mesh function:
Then you simply set it with a separate ssid.
Its easy enough to know if you're connected to 2.4ghz or 5ghz if they have different names
May 30, 2024Guru - Experienced User
Are you connecting to the 2.4ghz or the 5ghz?
2.4ghz is much much slower and sensitive to interference. Its not the network to use for streaming.
If it was me, I'd setup the EX6400 and disable its "mesh" or "single ssid" function. Leave it as a separate network so you can connect just the devices that are further away to it.
- dlange1234May 30, 2024Aspirant
Thanks for the input - how would I do that?
- dlange1234May 31, 2024Aspirant
Is there a way to do that without have to run Cat 5 as I am not able to do so do to the location of the other room.
- plemansMay 31, 2024Guru - Experienced User
- dlange1234Jun 15, 2024Aspirant
Thank you so much for the information, followed some very easy directions and this seems to of solved the lagging issue with extender to router.
This community is the best....
