dlange1234
May 28, 2024Aspirant
Netgear C7000v2 and EX6400v3
I am using AC1900 (model C7000v2, Firmware v1.03.08) in my home but the wifi signal was not making back to one of the rooms we use for streaming movies so I purchased the EX6400v3 (firmware V1.0.3.32...
- May 31, 2024
This is how to disable the mesh function:
Then you simply set it with a separate ssid.
Its easy enough to know if you're connected to 2.4ghz or 5ghz if they have different names
May 31, 2024Guru - Experienced User
dlange1234
Jun 15, 2024Aspirant
Thank you so much for the information, followed some very easy directions and this seems to of solved the lagging issue with extender to router.
This community is the best....
