Ahmedyounes
Dec 16, 2019Aspirant
Netgear c7500 or c7000
Which one is best to buy . Netgear c7500 or netgear c7000?
Dec 16, 2019Guru - Experienced User
I know. But I'd skip the c7500 for the c7800 if I was upgrading past c7000.
Ahmedyounes
Ok what the difference between c7000 and 7500
- plemansDec 16, 2019Guru - Experienced User
basically the same modem but the C7000 (600 Mbps + 1300 Mbps) is ac1900 while the C7500 is AC3200 (1000Mbps @2.4GHz with 1024 QAM support + 2200Mbps 5Ghz 11ac). Quite a few devices don't have 1024 QAM support. That's why i said I'd go for either the C7000 or C7800. The c7800 has the upgrade to docsis 3.1 which enables gigabit connection back to your isp.
