DVOR
Jun 29, 2021Follower
Netgear EAX20 Mesh Extender
Hello
I resently set up 2 EAX20 Wifi Mesh Extenders as Wireless Extenders- I am relizing that I would rather have them set up as AP's do I need to Factory restore these extenders or is there a way to do that in the GUI?
1 Reply
Either method would work and take about the same amount of time.
If you did it thorugh the gui, you'd re-run the setup assistant.
Or if you factory reset, you'd use the setup assistant during the install process. So its a wash in terms of time.
