Cyril92500
Jun 05, 2024Aspirant
NETGEAR EAX80 - connecting with a RS700s router
Hello, I own both a RS700 Wifi7 router and a EAX80 Wifi 6 wifi extender. The router works well, located on ground floor. Unfortunately, I have a Apple mac desktop on 2nd floor with WIFI5, and t...
Jun 05, 2024Guru - Experienced User
The EAX should connect fine to the RS, just won't get any 6Ghz or WiFi7 support thru the EAX. You should get both 2.4 and 5ghz signals thru though.
The NH app can handle both RS and EAX units. Just a switch with in the app to select the other device when you need it to connect it to either device.
- Cyril92500Jun 05, 2024Aspirant
Thanks a lot, pairing the 2 is my fear, but since I survived RS700s setup via the app, I shoul dbe able t survive if I can switch devices.
Wil let you know if it worked, and thanks again (especially if it enables me NOT to go to ORbi solution...)
- FURRYe38Jun 05, 2024Guru - Experienced User
Use the menu feature on the NH app and top section is what the NH app is connected too. Select this here and you'll see a list of devices you have the NH app connected too. You can select here back and forth.
- EurojazzNov 30, 2024AspirantThinking of about doing the same thing, did your setup work for you? Curious to find out if the extender is working well with the RS700. Thanks in advance for your input.
- FURRYe38Nov 30, 2024Guru - Experienced User
EAX80 works with my RS600.
