Cyril92500
Jun 05, 2024Aspirant
NETGEAR EAX80 - connecting with a RS700s router
Hello, I own both a RS700 Wifi7 router and a EAX80 Wifi 6 wifi extender. The router works well, located on ground floor. Unfortunately, I have a Apple mac desktop on 2nd floor with WIFI5, and t...
Cyril92500
Thanks a lot, pairing the 2 is my fear, but since I survived RS700s setup via the app, I shoul dbe able t survive if I can switch devices.
Wil let you know if it worked, and thanks again (especially if it enables me NOT to go to ORbi solution...)
Jun 05, 2024Guru - Experienced User
Use the menu feature on the NH app and top section is what the NH app is connected too. Select this here and you'll see a list of devices you have the NH app connected too. You can select here back and forth.
