jamielasagna
Mar 04, 2021Aspirant
Netgear EX2700 extender connected via ethernet, but saying I'm not connected on the Netgear Homepage
Title is pretty self-explanatory, my PC is connected to the Extender via Ethernet, but whenever I attempt to go to the Extender's homepage, the website says that I am not connected to the Extender's ...
Mar 04, 2021Guru - Experienced User
Are you able to access it using its ip address? NOT using the mywifiext . net
You can find its ip address in the routers attached devices page (or equivelent)
jamielasagna
Both 192.168.1.1 and 192.168.0.1 time out whenever I try and search them.
- plemansMar 04, 2021Guru - Experienced User
those are router ip addresses, not extender.
what router do you have?
if you open a command prompt on your computer, type ipconfig, the default ip address should be the address for the router.
