wdb2005's avatar
wdb2005
Follower
Apr 26, 2020
Netgear EX2700 Wifi Range Extender keeps disconnecting
My WiFi range extender keeps disconnecting. I have the latest firmware update and I've done a factory reset multiple of times and even a hard reset as well as having an ethernet cable connected to my computer yet the problem still continues to persist. Is there any way to fix this?
1 Reply
  • plemans's avatar
    What router are you using?
    the router is the backbone of the system and what the extender is running off.
    Have you setup a static ip address in the router for the extender?
