MammaWags
Dec 15, 2021Follower
NETGEAR EX3110-100NAS WiFi RANGE EXTENDER
I just purchased the Netgear EX3110 Dual Band WiFi Extender. I have a security system on my residence and am needing help to get WiFi to two (2) cameras that are outside on/in a garage not connected...
michaelkenward
Dec 16, 2021Guru - Experienced User
MammaWags wrote:
Is this model of extender strong enough to go walls and garage doors approximately 150'-200' away from the house??
It probably depends on the building material. Steel garage doors would be great at blocking wireless.
And 200 feet is a hell of a run for wifi.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
WiFi Range Extenders & Nighthawk Mesh - NETGEAR Communities
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
