Fred53
Apr 01, 2023Initiate
netgear ex3700 does not authenticate with t-mobile zyxel DX5401-B1 router
I want to use the EX3700 as an extender to the t-mobile zyxel DX5401-B1 router. I installed the latest firmware V10096_1.0.62 in the EX3700. Using the WPS procedure, the connection fails. Configur...
Apr 01, 2023Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
Fred53
Apr 03, 2023Initiate
Did you set it up using the push button WPS option? >> Yes I did but the connection failed over and over again
If so, factory reset the extender and set it up using the installation assistant. >> I did that and the authentication works. I assume that the problem is with the WPA... which is not supported by the EX3700.
I returned the Netgear extender and bought a Zyxel model.
Case closed
- plemansApr 03, 2023Guru - Experienced User
Fair enough. if you returned it you might mark this solved so others aren't still trying to fix it.
Good luck with your current setup
