kyu53's avatar
kyu53
Follower
Oct 01, 2016
Netgear Ex6100 AC750 or Netgear EX3700 AC750
I would like to extend my wifi signal to about 50 meters from my NBN box. There are many options on the market and I wonder what are the difference between Netgear Ex6100 AC750 or Netgear EX3700 AC750? which one is a newer model?
1 Reply
  • One major difference is that the EX6100 has a Gigabit Ethernet port, while the EX3700 has a Fast Ethernet port.  If you don't plan to use Ethernet, then remaining differences may not be that significant.  The EX6100 is probably newer.
