wsion
Jul 26, 2023Aspirant
Netgear EX6100 extender 5G SSID cannot be detected
Hi, I believe this is the support community. My AC750 range extender model EX6100 cannot have the 5G SSID detected. The firmware version is V1.0.2.24_1.1.134. And tried both Access Point mode as wel...
wsion
Also, I have tried a few times of Factory Reset by pushing the small hole at the side of the product, no luck.
Jul 26, 2023Guru - Experienced User
Your status page shows its broadcasting.
You might try upgrading to the 1.0.2.28 firmware and seeing if that helps. Maybe somethings corrupt in firmware.
I'd also try changing the ssid name to make it a little different so its easier to tell.
