sweetartnacho's avatar
Oct 14, 2022
NETGEAR EX6100 EXTENDER and ARRIS AC1200 ROUTER
ARE these 2 even COMPATIBLE???
I can not get these 2 to connect whatsoever. 😞
Any advice??
1 Reply
  • plemans's avatar
    Are you trying using the wps option?
    Or using the installation assistant?
    If you used the wps button, factory reset the extender  and set it up using the installation assistant.
    To factory reset, push and hold the reset button for 7-15 seconds while powered on.
    Here's a video of how to use the assistant.
    https://www.youtube.com/watch?v=yJVklshxBMk
    What error does it give you or what actual problem do you have when you try?
