CapeCodder
Dec 18, 2024Aspirant
Netgear EX6100 Extender won’t connect to wifi with iPhone
Xfinity modem/router doesn’t have a WPS button. Tried to choose the Netgear wifi network on the iPhone, it keeps spinning. Tried the mywifiext and variations. Never got the set up assistant. Got a pa...
CapeCodder
The modem/router doesn’t have a WPS button so I don’t know what pushing the button on the extender would do. …And it did nothing. Just tried it. Also did the factory reset earlier. Can’t get to the assistant page online.
Dec 18, 2024Guru - Experienced User
If you hit the wps, then reset it.
did you try a different device for setup? Like a pc/laptop?
What are the leds on the extender doing? (color/blinking/etc)
