Miii
Oct 30, 2024Aspirant
NetGear EX6100 Extender won't connect to WIFI
Hi Everyone, My internet company recently experienced an internet outage, and since then my wifi extender has been down. I tried factory resetting it, though since then it has been unable to connec...
Miii
Nov 01, 2024Aspirant
Thanks so much for your response, and I appreciate you sending the directive video. Unfortunately, after resetting the Wi-Fi extender, when I go to connect my device to the network NETGEAR_EXT there is no internet connection available to use the installation assistant. Is there another way to fix this?
Thanks in advance.
Nov 02, 2024Guru - Experienced User
you don't need an internet connection to set it up.
Once connected, go to mywifiext.net or 192.168.1.250 and go through setup. It won't connect to the internet until you've went through setup.
