Kie23
May 19, 2024Follower
netgear ex6110-100uks no internet connection
Purchase netgear ex6110-100uks today and set up correctly however when I connect to the extender on my devices it says not internet connection. Tried to restart the extender but to now use. Can any...
Sohail25
May 19, 2024Initiate
Here are a few steps you can try:
- Check the Main Router Connection
- Place the extender halfway between your router and the area with a weak signal.
- Reconnect Extender.
- Firmware Update.
- Reset Extender.
- Forget the extender network on your devices and reconnect.
If these steps don’t work, consider contacting Netgear support for further assistance.
