Kie23
May 19, 2024Follower
netgear ex6110-100uks no internet connection
Purchase netgear ex6110-100uks today and set up correctly however when I connect to the extender on my devices it says not internet connection. Tried to restart the extender but to now use. Can any...
May 20, 2024Guru - Experienced User
Did you set it up using the push button WPS option?
If so, factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
