Giada0111
Mar 20, 2020Follower
netgear ex6110 non riconosce password
Salve, ho acquistato un extender wifi modello ex6110, quando lo configuro con il tasto WPS funziona ma nel momento che cerco di collegare il telefono o pc inserisco la password del router e mi dice ...
Mar 20, 2020Guru - Experienced User
Start back at the beginning.
Factory reset by pushing and holding the reset button while its powered on for 7-15 seconds. this will default the extender back to the default netgear ssid and disconnect it from the router. connect to that and then follow the install guide for the installation wizard.
https://www.netgear.com/support/product/EX6110.aspx
- IvanoFMar 30, 2020AspirantNon riconosce la password del router. Dice che è errata. Ho fatto il reset 3 volte. Sempre stesso risultato: password errata.
Io ho EX6120. - IvanoFMar 30, 2020AspirantGia fatto. Non funziona. Mi dice sempre password errata
- plemansMar 30, 2020Guru - Experienced User
Did you setup via wps? don't use that method. Not all device makers code wps the same.
how are you doing the setup?
you need to go into details for me to help you. The more brief you are, the less I can help. Describe how you're setting up, what you're doing, where its failing, etc.
Does your password/ssid have any special characters/spaces in it? if so, remove them.
