JanisLP's avatar
JanisLP
netgear ex6110
hello, 5ghz working,but 2ghz stop working ,cant connect,showing password wrong,but password are correct,i did reset and reset rooter to,does not help,same issue. what can i do ? please,thanks.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi JanisLP, after completing the extender setup, you can access the extender UI and confirm if the password saved is the correct one and/or change it and see if the issue will persist.
    Dexter
    • JanisLP's avatar
      JanisLP
      does not help at all,i change a password,but no any changes ,still same issue,i just damage this rubbish and put in bin better,bye netgear.
