PM63's avatar
PM63
Netgear EX6110/AC1200
I just purchased to range extender but cannot connect because I am unable to locate the WPS button on my Netgear N300 model C3000 router.  Where is it located?
  • plemans's avatar
    Its the top button. the manual has a diagram that points to it.
    https://www.netgear.com/support/product/C3000.aspx
    You can also use the installation assistant withthe EX6110.
    Might look at upgrading the modem/router at some point. its a base model N300 router and its wireless is going to be the bottleneck for speeds.
