dnlaucella
Sep 30, 2024Follower
NetGear EX6120 AC 1200 WIFI Extender - Create New WiFi Connection to Replace former WiFi Connection
I purchased the NetGear EX6120 AC 1200 WiFi Range Extender in Aug 2022, and it no longer has NetGear software support. We just completed a move and are on a new WiFi Connection and router/modem w...
Oct 01, 2024Guru - Experienced User
Factory reset the extender and set it up using the installation assistant.
To factory reset, push and hold the reset button for 7-15 seconds while powered on.
Here's a video of how to use the assistant.
https://www.youtube.com/watch?v=yJVklshxBMk
