Chris9393
Jan 20, 2021Tutor
Netgear Ex6120 AP Mode Speed
Hi, I currently have my Netgear Ex6120 setup in AP mode via ethernet cable running directly from my router with a Cat6 cable. My Internet speeds via the router are around 360Mbps which is what I am c...
Jan 20, 2021Guru - Experienced User
When you're testing in AP mode, are you testing on 5ghz or 2.4gh?
2.4ghz is much much slower.
Have you tried testing the cable that's connected to the EX6120 to ensure the cable supports full speeds?
Chris9393
Jan 20, 2021Tutor
This is from running on the 5GHz connection. I hadn't actually thought about trying another cable, albeit I don't have one spare as they were provided by the electrician when we had our house rewired and installed the etherenet sockets.
I've just ordered 2 Cat6 cables and will give them a try tomorrow
- Chris9393Jan 21, 2021TutorJust an update, I've replaced both cables WITH Cat6 and still getting the same speeds around 40-50Mmbps. If I plug my laptop or computer directly into the ethernet wall socket I get my full speeds so it is definitely the booster holding it back.
What I have noticed is that on Netgear 7800 router, the connection flashes orange when it's connecting into the Ex6120. If I remove the ethernet cable and plug it directly into a computer or laptop it goes white.- plemansJan 21, 2021Guru - Experienced User
Have you tried factory resetting the extender?
How old is the extender?
What firmware is on it?
- Chris9393Jan 21, 2021TutorTried factory resetting. Purchased the Extender from Amazon just under a year ago and running on the latest firmware.
- michaelkenwardJan 21, 2021Guru - Experienced User
Chris9393 wrote:
What I have noticed is that on Netgear 7800 router, the connection flashes orange when it's connecting into the Ex6120.What connection flashes orange?
Anything other than white for the Ethernet LED is a sign that the R7800 and EX6120 are communicating at 100 Mbps.
Are you using Ethernet cable embedded into the property? It is anybody's guess what the electrician did there. The cables you plug into the wall are only a part of it.
The connection port on the R7800 router flashes orange which is connecting into and ethernet wallsocket. All cables have been checked to make sure they are connected properly. I have also tried changing ethernet ports in the back of the router, however, whatever socket I plug it into, it flashes orange.
If I plug an ethernet cable directly into a laptop, instead of the EX6120 from the recieving ethernet port, I get full speeds.
